Date/Time: Tue, 22 Apr 2025 14:11:45 +0000
Orders (and positions) put on DOM need to show up on chart
View Count: 896
[2023-03-14 15:55:17] |
TEvans622 - Posts: 3 |
Hi there, how can I see the orders that I place on the DOM rendered on the related chart. Also I want to be able to move my order around on the chart and have the order move on the DOM |
[2023-03-14 20:28:32] |
This is all possible. The main thing is that the symbol has to be the same between the DOM and the Chart. The other item is that the Trade Account has to be the same for both. Refer to the following with regards to the Trading Account: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) One other main item is that the Chart and Trade DOM both need to have the option for Trade >> Show Order Fills enabled (have a checkmark next to it). And if you want to be able to modify the orders on the chart, then make sure the option for Trade >> Chart Trade Mode On is enabled. Refer to the following for more on this topic: Chart Trading and the Chart DOM: Viewing Orders and Trade Position on the Chart / Trade DOM For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
