Date/Time: Thu, 19 Sep 2024 01:23:50 +0000
limit/market orders filet
View Count: 1059
[2014-06-16 19:10:33] |
User45038 - Posts: 10 |
Dear Support, Is it possible to filter positions results opened by market and separately limit orders in the trading activity log? I would like to see the results from market orders and limit orders each. I hope you understand my question. Thank you for help! |
[2014-06-17 09:37:23] |
No. You can filter by Symbol and Trade Account and Date Range. However, you can always save the data to a text file and then open it up in a spreadsheet and then do whatever filtering you want. Refer to the documentation here: http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#Saving Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
