Date/Time: Tue, 22 Apr 2025 18:30:44 +0000
Printing Issues
View Count: 541
[2023-03-14 15:25:05]
User466872 - Posts: 6
Every time I print a chart, the first time it prints. If I try to print again the software crashes. It has been happening since the beginning of the trial. It crashes and hangs and I have to force a close.
[2023-03-14 15:37:19]
Sierra_Chart Engineering - Posts: 19305
We cannot help with this. It is not an issue we would be able to reproduce. Try printing to a PDF and then print that PDF.
Date Time Of Last Edit: 2023-03-14 15:37:33
[2023-03-14 21:49:04]
Printing to PDF causes the same issues. Is it a Windows11 Issue? NinjaTrader is having a similar issue with some Windows Updates and prints a blank.
[2023-03-19 17:09:55]
I managed to resolve the issue. It was a Windows 11 issue. In case anyone else has this problem this is the solution:
https://www.winhelponline.com/blog/restore-legacy-print-dialog-windows-11/?utm_content=cmp-true
[2023-03-19 18:53:37]
Okay thank you.
