Date/Time: Tue, 26 Nov 2024 08:34:25 +0000
Binance Futures data feed stopped at 14:44 UTC today
View Count: 409
[2023-03-14 15:16:35] |
Rife_ - Posts: 5 |
There has been 'hiccups' with Binance Futures data in the last couple of days. Today all symbols have been stuck since 14:44 UTC. Other exchanges work as expected. I have submitted my message log. |
[2023-03-14 15:34:03] |
Sierra_Chart Engineering - Posts: 17179 |
What symbol?
[2023-03-15 07:06:18] |
Rife_ - Posts: 5 |
It seems to affect any of Binance's Futures (_PERP_) symbols, such as BTCUSDT_PERP_BINANCE or ETHUSDT_PERP_BINANCE Today after opening Sierra, it loaded until 6:45am UTC on BTCUSDT_PERP_BINANCE and 4:44am UTC on ETHUSDT_PERP_BINANCE I have sent the message log from today too |
[2023-03-15 07:35:40] |
Use the Bitmex symbols when you have an issue with Binance symbols.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-15 07:35:52
[2023-12-11 19:39:19] |
Binance should now be working much better now: Notice: Binance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
