Date/Time: Mon, 15 Dec 2025 09:11:49 +0000
Select Files To Open On Startup does not let me modify a previous choice
View Count: 455
| [2023-03-14 10:13:55] |
| trader2017 - Posts: 117 |
In Global Settings the Select Files To Open On Startup field presents a button. From there I had selected 3 chartbooks but am unable to change that to select only 1 of those 3 chartbooks to open at startup, it keeps opening all 3. I tried selecting Revert All and then selecting just the 1 chartbook and it still opened all 3. Next, I went into each chartbook one at a time and changed the settings to Revert All and then selected just the 1 chartbook and that too opened all 3. How to I get it to open only 1 chartbook other than changing the names of the chartbooks so it can’t find them to open. Thank you. |
| [2023-03-14 16:21:52] |
| Sierra_Chart Engineering - Posts: 21843 |
You need to remove all the Chartbooks from that list that you do not want automatically open. There is no revert button. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
