Date/Time: Tue, 11 Mar 2025 05:11:55 +0000
Alert Question
View Count: 1187
[2014-06-16 18:43:34] |
infpz - Posts: 826 |
If I’m using the time line study (draws vertical lines) and I want it to issue an alert when it draws the line, what’s the syntax I need in the alert tab?
[2014-06-16 19:16:25] |
The Alert Condition Formula is: =sg1>0 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
