Date/Time: Tue, 22 Apr 2025 13:45:21 +0000
Is TICK_NYSE_NASDAQ_NYSEMKT the closest
View Count: 369
[2023-03-13 19:13:40] |
User337568 - Posts: 61 |
Hi: 1. Is TICK_NYSE_NASDAQ_NYSEMKT with the widest (all US) tick symbol we have? 2. I am trying to do a cumulative value over 30 days. Is this possible on TICK_NYSE_NASDAQ_NYSEMKT? Thank you |
[2023-03-13 21:49:36] |
1. Yes, that would be the statistic with the widest coverage. 2. It should be, but we do not know exactly what you are wanting to do. Give it a try and see. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-13 22:26:34] |
I am trying to compare it to another platform. The other platform said their most composite tick is "all US listed stocks and a composite of up or down tick amongst all exchanges and not their primary exchange." Reviewing their reply, "not their primary exchange," doesn't make sense. This is going nowhere if I have to determine what "not their primary exchange means regarding ticks." Thank you for your reply. |
[2023-03-13 22:45:32] |
We never recommend comparisons to other platforms. Too many differences and subtleties. All we can say is that our data is what we state it is. In this case, you will find the information for this data at the following link: Sierra Chart Market Statistics For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
