Date/Time: Tue, 22 Apr 2025 14:26:36 +0000
Daily es hostorical data isn't correct
View Count: 337
[2023-03-13 18:22:29] |
YuvalIsm - Posts: 4 |
hello, I have noticed that my ES future contract daily graph has worng values. The only values that correct is the ones that in the presenet contract, but all the values of the past contract is wrong. How can I get them accurate it is immposible to trade like that. Thank you |
[2023-03-13 21:32:15] |
You must be using a Continuous Contract with Back-Adjusting. Use a different option that does not use the Back-Adjustment if you want to see the prices as they were for the specific contract. Refer to the following: Continuous Futures Contract Charts: Continuous Futures Contract Rollover Options For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
