Date/Time: Sun, 20 Sep 2026 09:39:11 +0000
spreadsheet system/alert don't trade when in excel
View Count: 1348
| [2014-06-16 18:27:15] |
| tal - Posts: 4 |
when i use the spreadsheet when the "use excel" set to no i can see the "buy entry","buy exit".... and when the value is true then a trade occurs but when the "use excel" set to yes non of this happens. please help thank you |
| [2014-06-16 18:33:19] |
The Use Excel option is not available with the Spreadsheet System for Trading study and we do not provide any support for that option. We highly recommend not using Excel. The interface to Excel is not considered reliable because a reliable interface is not available to excel in general . Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-06-17 12:06:23] |
| tal - Posts: 4 |
but i am using excel and i have an algorithm in vba excel so i have to use it! is there any way to do it??? |
| [2014-06-17 16:30:31] |
No there is not. We would not support something which is inherently unreliable. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-17 16:30:52
