Date/Time: Fri, 22 Nov 2024 21:35:17 +0000
DOM - Current traded bid & ask
View Count: 657
[2023-03-13 16:59:02]
sean.sean - Posts: 5
Is there a way to have the DOM show the full current traded bid and ask for an intraday session (or based on a previous time range)? I don't quite know if I am wording the properly. If I open sierra chart, at any point, the data in the current traded bid and ask columns only reflects what has traded since I opened the program. I would like to have it reflect what has traded since the open (or for given time range), but I am not sure if this is possible. I have attached a picture and drawn an arrow to the column.
Thank you for your time,
Sean
imageScreen Shot 2023-03-13 at 12.53.22 PM.png / V - Attached On 2023-03-13 16:58:09 UTC - Size: 49.96 KB - 128 views
[2023-03-13 20:47:48]
You would have to have Sierra Chart running at the time you want and then specifically reset the column at the time you want. Refer to the following:
Trade Menu: Clear Current Traded Bid/Ask Volume (Trade menu)
[2024-09-25 12:47:40]
tradewerx - Posts: 6
Following up on this. Is there a way to implement this with volume profile analysis on the dom?
[2024-09-25 14:54:33]
We are not sure of what exactly you are asking about. In what way do you want to use the Volume Profile?
