Date/Time: Tue, 22 Apr 2025 14:08:53 +0000
PROBLEMAS DE CONFIGURACION
View Count: 262
[2023-03-13 15:30:25] |
trmm - Posts: 1 |
Tengo problemas con mi configuración , el periodo A (inicial) abre 30 min antes, por favor su ayuda. Gracias |
[2023-03-13 20:33:58] |
From Google Translate: I have problems with my configuration, period A (initial) opens 30 min earlier, please help.
We are not sure exactly what the issue is, but check your Session Times to make sure they are correct. Refer to the following: Chart Session Times For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
