Date/Time: Thu, 19 Sep 2024 01:20:32 +0000
ASX symbols
View Count: 1089
[2014-06-16 17:02:13] |
EuropeanTrader - Posts: 290 |
Hi, I do get a stock chart on but not an index chart on with SC Historical data feed. How can I see index as well, please? STOCK sample AAD.AX http://www.sierrachart.com/image.php?l=1402938070504.png works INDEX sample XAT.AX http://www.sierrachart.com/image.php?l=1402938110741.png blank ? thank you |
[2014-06-16 18:00:26] |
If you do not get data for a particular symbol, then this means there is no data available for it.
