Date/Time: Mon, 15 Dec 2025 09:11:50 +0000
Is there a limit order type that tracks bid/ask -/+ X number of ticks?
View Count: 637
| [2023-03-13 10:32:36] |
| User799255 - Posts: 24 |
I can't seem to find it. But it's a basic futures spread strategy. Apologies if it already exists. I want to show limit order of both bid and ask in one market that is 2 ticks off the best bid and ask and wait for aggressive order to sweep then have contingent order to hedge aggressively in a different market. Is this possible? Thank you. |
| [2023-03-13 16:39:13] |
bumping for visibility
| [2023-03-13 23:49:27] |
| Sierra_Chart Engineering - Posts: 21843 |
All of the Sierra Chart order types are here: Order Types If you cannot find what you want, it does not exist. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-13 23:49:34
