Date/Time: Tue, 11 Mar 2025 05:07:57 +0000
More questions
View Count: 1100
[2014-06-16 16:47:03] |
dayman - Posts: 12 |
Thanks for your assistance once again: 1. When placing an order on FXCM, a sell stop/sell limit (or buy stop/buy limit) order will trigger once the bid price hits where the order is set a rather than when the "last trade price" hits this, as in trade simulation mode in Sierra Chart. Is there any setting to change this? 2. When having a chartbook open and making a drawing for a support or resistance line on a higher time frame chart, is it possible to have this drawing appear on a shorter time frame chart within the same chartbook? |
[2014-06-16 16:53:42] |
1. No. How could there possibly be a setting within Sierra Chart that would affect on how orders are filled on the FXCM system? There cannot be. 2. Yes. Refer to: http://www.sierrachart.com/index.php?l=doc/helpdetails72.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-06-16 17:14:01] |
Thanks for your quick response. Not sure why the answer to question 1 needed to be worded that way though. This is my first month subscribing to Sierra Chart as well as my first month trading. No need to make me feel dumb for asking a question. I'm still learning how everything works.
[2014-06-16 18:31:00] |
OK.
