Date/Time: Tue, 22 Apr 2025 14:23:35 +0000
Historical Chart not loading
View Count: 440
[2023-03-13 00:07:59]
User148596 - Posts: 217
Hi, for some reason my NQ chart will only load the March contract. I have it set to continuous futures contract and days to load is 900.
Any thoughts?
[2023-03-13 00:53:33]
Barry L - Posts: 33
I had the same carry on last night rolling to the ES June , But only on one chart. Just kept going back to the March . I thought it may have been some of the correlation studies that was doing it , Saved the whole study collection , then cleaned the chart and it still wouldn't load the June on the bare candles .So I duplicated one of the other charts that would load and cleaned it, and then applied the study collection and it worked fine , so I just deleted the other one, But none of my Historical market depth studies are showing anything for the June , even with lowering the threshold to colour way way down
Update . Solved the problem by just making a duplicate chart and the Depth appeared on that one
Date Time Of Last Edit: 2023-03-13 01:22:55
[2023-03-13 09:17:43]
Sierra_Chart Engineering - Posts: 19305
Provide an image of the chart or Trade DOM, by following these instructions:
[2023-03-14 03:15:00]
https://www.sierrachart.com/image.php?Image=1678763667196.png
[2023-03-14 11:08:39]
This is what we see:
https://www.sierrachart.com/image.php?Image=1678792054213.png
Follow through the instructions here:
For now do not use the back adjusted option.
Date Time Of Last Edit: 2023-03-14 11:09:30
[2023-03-15 13:02:37]
Okay, but why is the link to the image a different image and link than the link/image I posted?
[2023-03-15 14:37:45]
It is to our own chart we created for the symbol to check the data and settings. And confirm there should be no problem if you re-download data.
