Date/Time: Tue, 22 Apr 2025 18:33:48 +0000
[Programming Help] - ACSIL Custom Array Question reference
View Count: 519
[2023-03-12 16:32:49]
User213910 - Posts: 17
i have an Custom 2D Array (Array[Variable][12]) in an Study(1). How can i get this Array Data in another Study(2) for e.g. on an other timeframe Chart?
GetPersistent will not do Arrays, or?
Thanks for help
Date Time Of Last Edit: 2023-03-15 17:01:17
[2023-03-15 17:00:11]
Anyone can help please?
[2023-03-15 17:55:49]
Tony - Posts: 565
I assume those 2 charts are in the same chartbook, and 2 studies are in the same .cpp/.dll file
What I am doing now is put array outside/above those 2 studies as public, then both studies will
have access. The coding part could be tricky though, especially when both studies need to change
the values of that array.
[2023-03-16 09:49:16]
Thank you very much, i will try that. The 2.Study only needs to read the Data.
[2023-03-16 17:33:17]
User275839 - Posts: 67
There is this on using globals in the Sierra docs as well:
ACSIL Programming Concepts: Global Variables
