Date/Time: Thu, 19 Sep 2024 00:16:43 +0000
SC Data on Hard Drive
View Count: 1006
[2014-06-16 15:20:31] |
User29707 - Posts: 43 |
Old SC data files keep piling up on my hard drive, is there an easy way to delete the out of date futures data files?
[2014-06-16 16:10:05] |
Yes. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_ChartDataFiles.html#DeletingCharts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-16 16:10:30
