Date/Time: Tue, 22 Apr 2025 13:39:30 +0000
Swing Pivots High Low
View Count: 499
[2023-03-11 16:02:01]
Ticks - Posts: 206
Is there a current study/studies that can provide these same features as this TradingView indicator?
https://www.tradingview.com/script/mcWqW3SB-Swing-Pivots-High-Low/
The screenshot is also attached.
The visual display on the chart is not really what I care about.
What I do need is the values provided by the pivots and swing high/low.
I need to capture those values to be used in my stop loss.
Date Time Of Last Edit: 2023-03-11 20:10:38
imageSwing Pivots High Low.PNG / V - Attached On 2023-03-11 16:01:06 UTC - Size: 84.53 KB - 111 views
[2023-03-12 15:36:11]
Ticks - Posts: 206
Solved using the SC Swing High and Low study.
