Date/Time: Thu, 19 Sep 2024 01:10:51 +0000
Rollover Issue
View Count: 1034
[2014-06-16 14:42:01] |
User29707 - Posts: 43 |
Rollover to TF-201409-NYBOT no streaming data just the Words"Hostorical Data. Bars may not appear" All other futures symbols OK. TF-201406 and earlier is OK. IB is Broker |
[2014-06-16 15:18:33] |
It finally updated, no need to repond
[2014-06-16 16:07:41] |
This is because of the long amount of time to download data reliably from Interactive Brokers. Refer to this section here: http://www.sierrachart.com/index.php?l=doc/IB.php#IBHDGeneralInformation The solution to this problem is to update Sierra Chart to the latest prerelease with Help >> Download Prerelease so that the Sierra Chart Historical Data Service is used instead. Refer to the version notes for 1141 here: http://www.sierrachart.com/index.php?l=doc/Whats_New.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-16 16:08:53
