Date/Time: Tue, 22 Apr 2025 13:57:14 +0000
Chart DOM -- Positions under Text Labels
View Count: 465
[2023-03-10 21:37:38] |
DayTraderEsad - Posts: 121 |
Hey guys, I am stuck on this and can't figure out how to have the positions and orders to be above text display when using Chart Trade Mode. I attached a pic. Thanks for the help |
[2023-03-10 22:45:50] |
How is the information on the left with the Grey background being drawn?
[2023-03-10 22:50:58] |
It's the Text display study from Chart
[2023-03-13 15:17:16] |
In this case, on the Text Display for Study from Chart you need to enable the option for Draw Study Underneath Main Price Graph. This will then have the order line above it. Refer to the following: Chart Studies: Settings and Inputs Tab >> Draw Study Underneath Main Price Graph (in the same Chart Region) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-13 15:54:40] |
I actually did that, but the same issue happens, even the candles are behind it as well.
[2023-03-13 20:40:33] |
We are not understanding the last statement. The study should definitely have moved behind the candles, as well as the order line. Is this not what you are seeing?
[2023-03-14 02:52:56] |
I attached a pic so you can see, I did enable the option to Draw Study Underneath Main Price Graph, and the candles are still behind it along with the order line.
[2023-03-14 17:09:04] |
Can you please get us that chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
