Date/Time: Thu, 19 Sep 2024 01:08:05 +0000
Using the arrow function
View Count: 1020
[2014-06-16 14:03:48] |
User41512 - Posts: 58 |
When drawing arrows on a chart,(call it chart A) i sometimes use the copy chart drawings function which copies these arrows onto another chart.(call it chart B) which is normally a lower time-frame chart). I have noticed that when i open the chartbook each new day, the arrows on chart B have moved slightly, which then means that i need to re-adjust them on Chart A to get them back in line on Chart B. This has also started to happen DURING the day as well, so its becoming problematic. I Have just loaded the current version 1137, but this did not cure the problem. Can you please advise. Thks |
[2014-06-16 18:30:31] |
Refer to this help topic: https://www.sierrachart.com/index.php?l=doc/helpdetails34.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
