Date/Time: Fri, 02 Oct 2026 11:10:48 +0000
ACSIL study won't use Trade Window attached orders
View Count: 3311
| [2023-03-10 18:57:29] |
| tecman240 - Posts: 18 |
Hi, I'm creating an ACSIL study that creates a Stop-Limit entry order. The study will create the entry order, but I can't get it to include the attached orders defined in the Trade Window. My study has the following set: sc.AllowOnlyOneTradePerBar = 1;
sc.SupportAttachedOrdersForTrading = 1; sc.MaintainTradeStatisticsAndTradesData = true; sc.ReceivePointerEvents = ACS_RECEIVE_POINTER_EVENTS_WHEN_ACS_BUTTON_ENABLED; sc.AllowMultipleEntriesInSameDirection = true; sc.MaximumPositionAllowed = 3; I've also tried setting sc.TradeWindowConfigFileName but that doesn't work either. I must be missing something. thanks, |
| [2023-03-10 19:57:49] |
| User90125 - Posts: 715 |
Try adding this to the sc.SetDefaults block: sc.UseGUIAttachedOrderSetting = true;
See ACSIL Interface Members - Variables and Arrays: sc.UseGUIAttachedOrderSetting for more info. |
| [2023-03-10 20:28:09] |
The attached orders now appear, however If I don't set the order quantity in my study, no orders are placed. Is there a way to have the study use the current quantity specified in the Trade Window? thank you. |
| [2023-03-10 20:35:39] |
| User431178 - Posts: 908 |
ACSIL Interface Members - Variables and Arrays: sc.TradeWindowOrderQuantity
| [2023-03-10 22:56:49] |
Also make sure sc.MaintainTradeStatisticsAndTradesData is enabled in the SetDefaults block too, which it apparently is in the code you posted above.
Date Time Of Last Edit: 2023-03-10 22:59:24
| [2023-03-11 16:37:06] |
Thanks, now the study quantity matches the trade window, however I get this Trade Log error message when trying to enter a position with quantity = 2: Auto-trade: MESH23_FUT_CME[M] Rev. 6t #2 | Next Reversal Open | SellEntry | Bar start date-time: 2023-03-10 15:47:18.014 | SellEntry signal is ignored because maximum Short Position quantity allowed has been reached or would be exceeded with new order. Max. Position allowed: 1. Resulting Position without working orders: -2. Resulting Position with all working orders except exits: -2. Resulting Position with Market working orders: -2 | 2023-03-10 15:51:27.705
I can't figure out where this position limit error is coming from: The Trade Position window shows no positions before attempting the above entry. In my study I have sc.MaximumPositionAllowed = 4 in the SetDefaults section. In Global Settings>>Symbol Settings: - Use Global Trade Position Limit is unchecked, - Symbol MES?##_FUT_CME Trade Position Limit =0 and Order Quantity Limit = 0 thank you for the help. |
| [2023-03-11 18:09:09] |
Somewhere in your code or your setup, something is enforcing a Max Position of just 1 contract. |
| [2023-03-13 15:15:44] |
It must have been something with the simulator position. I cleared sim positions & data and now it works.
