Date/Time: Tue, 22 Apr 2025 14:14:46 +0000
Export daily Initial balance data and daily range data for past 2 years.
View Count: 361
[2023-03-10 15:58:18] |
User454729 - Posts: 22 |
Hi I am trying to export daily initial balance data and daily range for analysis in excel. I tried the IB study, but it is not clean as it comes with other data. I tried doing IB study on a daily chart and even a 1440m chart, but it doesn't work. Any help is really appreciated. Thank you
[2023-03-10 20:29:29] |
What is the issue with the Initial Balance study in terms of "it is not clean as it comes with other data"? How are you exporting the data?
[2023-03-10 22:37:54] |
I tried the initial balance study on a 1440min (1d chart) so that I can just get each row corresponding to 1 day and the IB data, but it doesn't work out. I tried something like 10min chart, it will have IB data every few rows, while the rest are "zero", which is not ideal because I have to clean up the data to delete those rows with no IB data.
[2023-03-10 22:50:22] |
