Date/Time: Tue, 22 Apr 2025 14:14:46 +0000
Message Log
View Count: 357
[2023-03-10 15:28:51]
Twin18 - Posts: 11
Hello, I want upload this custom chartbook settings I have but for some reason they will not load onto my chart.The name of my file is CLT_Recording_.Cht let me know if you can see it.
[2023-03-10 20:27:08]
John - SC Support - Posts: 39395
There is nothing attached to this thread. But we do not understand what your issue is. A file that has an extension of .cht is a Sierra Chart Chartbook. You would open this chartbook and then have charts within it. It is not a settings file.
To open the file, refer to the following (Skip to step 3 and copy the file to the noted location):
Chartbooks (Workspaces): Using a Chartbook Provided by Sierra Chart Support
