Date/Time: Tue, 22 Apr 2025 14:32:25 +0000
See DVP in the background of the chart
View Count: 326
[2023-03-10 12:53:46]
User285770 - Posts: 41
Hello
Where I control the DVP Volume Profile Tool?... I want to see it in the background of the chart
Thank you
[2023-03-10 19:57:33]
John - SC Support - Posts: 39395
If you have not already done so, then you would need to setup a Configuration for the Drawn Volume Profile, which means creating a Study Collection for the Volume by Price study, where the study is setup as you want it. In that setup, you want to ensure you set the option for Draw Study Underneath Main Price Graph. Refer to the following for this setting:
Chart Studies: Settings and Inputs Tab >> Draw Study Underneath Main Price Graph (in the same Chart Region)
And refer to the following instructions to setup a configuration for the Drawn Volume Profile:
Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool
