Date/Time: Tue, 22 Apr 2025 10:23:22 +0000
HI LITEL Q
View Count: 297
[2023-03-10 12:53:26] |
User542166 - Posts: 17 |
hi i try to open my siera chart and this happen me and i can do anything what i should do? ty |
[2023-03-10 13:02:16] |
Sierra_Chart Engineering - Posts: 19305 |
You need to translate the symbols using this command: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
