Date/Time: Sat, 12 Sep 2026 19:10:16 +0000
Sierra Chart Data Feed - Missing UB Futures (Ultra 30yr Bond Futures from CBOT)
View Count: 2042
| [2014-06-16 13:49:21] |
| User71961 - Posts: 144 |
i just subscribed to the Sierra Chart Data feed (CME/CBOT exchange), and i want to bring up a chart for UB futures (from the CBOT) http://www.cmegroup.com/trading/interest-rates/us-treasury/ultra-t-bond_contract_specifications.html however, i don't see this contract as an option in the list?? Can these contracts be added?? |
| [2014-06-16 18:25:31] |
What trading service do you trade through? To access the real-time CME data, you need to use one of the supported trading services. Refer to: https://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME Please let us know what Trading service you use, so we can make sure the proper mapping is set up for the UB futures. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-06-16 18:37:33] |
i am using Interactive Brokers for my trading service...but i purchased the Sierra Chart Data Feed so the Numbers Volume charts would be accurate.
| [2014-06-16 18:50:24] |
Change the Service in Sierra Chart to Interactive Brokers through Global Settings >>Data/Trade Service Settings. Update the Symbol Settings as explained here: https://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings You will now see the UB symbol listed under the Futures symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
