Date/Time: Tue, 22 Apr 2025 10:32:32 +0000
Unable to move heat map horizontally. Is there any fix?
View Count: 396
[2023-03-10 04:50:21] |
User280673 - Posts: 27 |
As the title says I am unable to move the heat map horizontally. The hand tool moves the time axis horizontally but there is this bar that cuts off the candle sticks that I cannot shift to left or right leaving a large gray area when zooming into the more granular price action. I have looked around for a while and found nothing to resolve. It seems like it should be a simple fix. However, I have tweaked a variety of settings with no success. Please refer to the image below for more info. https://www.sierrachart.com/image.php?Image=1678423203934.png |
[2023-03-10 08:57:00] |
Sierra_Chart Engineering - Posts: 19305 |
Follow the instructions here: Working With Charts: Removing Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
