Date/Time: Tue, 22 Apr 2025 14:11:45 +0000
Unirenko Chart loads slow
View Count: 676
[2023-03-09 17:49:32] |
User296908 - Posts: 6 |
Hello. Just switched to Sierra. I'm using a unirenko chart, and when I switch to another account it takes 60secs plus to load. I was able to switch from acct to acct on NinjaTrader seamlessly. Is this normal in Sierra? Any advice? Thanks in advance. |
[2023-03-09 18:56:10] |
There are a lot of factors involved in how long it will take to load a chart, so 60s is possible. But we do not understand the statement of "when I switch to another account". The charts should not reload when you switch accounts, or are you changing your Data/Trade Service Settings? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-09 22:31:24] |
@john - To clarify....I have multiple accounts with a prop firm. If I switch from Acct1 to Acct2, the unirenko chart takes 60 seconds plus to load. It "reloads" the data. I am not changing my Data/Trade Service settings. |
[2023-03-10 18:45:45] |
Are you just selecting a different account on the Trade Window? Where are you changing the account?
[2023-03-14 12:15:38] |
@john - Yes. I'm selecting different accounts on the Trade Window. (the dropdown next to the "buy bid" button.)
[2023-03-14 12:59:46] |
Sierra_Chart Engineering - Posts: 19305 |
This is not normal. The problem would relate to the chart and the time to calculate the studies within it. Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: Sierra Chart Provided Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-14 13:20:39
