Date/Time: Tue, 22 Apr 2025 14:41:16 +0000
Settings aren't applied after they are changed
View Count: 352
[2023-03-09 17:29:20]
Daren Hampton - Posts: 27
I was trying to change the overnight profile to another color different from the daily tpo profile. The settings simply didn't apply after changing them and pressing "Apply."
I was assuming that I may need to reset the platform or something.
Thanks in advance.
[2023-03-09 17:30:08]
I also wanted some help creating a weekly tpo profile with data from Monday to Monday with RTH data.
[2023-03-09 18:38:15]
John - SC Support - Posts: 39395
Exactly which setting were you changing?
Set the Chart to be RTH only, then add the TPO and set the Profile Time Period Length to 1 and the Profile Time Period Length Unit to Weeks. Refer to these Inputs at the following link and the section after it:
Time Price Opportunity (TPO) Profile Charts: Profile Time Period Length
[2023-03-10 02:57:32]
The setting that I was trying to change was TPO Letter/Block Color (SG13)
[2023-03-10 19:00:01]
Refer to the information for that particular subgraph and when it can be used and what it affects at the following link:
Time Price Opportunity (TPO) Profile Charts: TPO Letter/Block Color (SG13)
