Date/Time: Tue, 26 Nov 2024 22:16:14 +0000
using a .cpp file
View Count: 2282
[2014-06-16 12:47:14]
AKR - Posts: 523
I wanted to use a given code in a.cpp file.
I read the instructions ...
what I did:
check there is
#include "sierrachart.h"
SCDLLName("RelVolume")
on top of file and save it to sc/ACS_source
I go to analysis / build custom studd dll
I select the file from acs_source folder
(I pressed install compiler as was not installed)
I press build custom studies dll
the output sais it did it and saved to SC/data.
but I can not find any DLL file in my data folder.
any help?
[2014-06-16 18:28:41]
After building the custom studies DLL, copy the text in the Build Output section of the Build Advanced Custom Studies DLL window and paste it here.
[2014-06-17 06:22:40]
AKR - Posts: 523
-- Starting build of Custom Studies Source files: relVolume.cpp. -- 08:21:35
"C:\SierraChart\CPPCompiler\bin\g++.exe" "C:\SierraChart\ACS_Source\relVolume.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "C:\SierraChart\Data\relVolume.dll"
-- End of Build -- 08:21:35
[2014-06-17 07:08:35]
So this file is not being generated?:
Does that folder actually exist on your system?
Are you running any security software which could prevent the DLL from being created?
[2014-06-17 07:14:16]
AKR - Posts: 523
yes sure it exists. I am running avast antivirus
no, file is not there
Date Time Of Last Edit: 2014-06-17 07:14:39
[2014-06-17 07:17:23]
The basic answer at this time is we do not know what the problem is. We did not develop the compiler and it is not giving any indication of an error creating that file.
Date Time Of Last Edit: 2014-06-17 07:17:35
[2014-06-17 07:19:54]
AKR - Posts: 523
ok. no big deal anyway. at least at the moment.
[2014-06-24 06:09:03]
We now know why this problem is happening. Refer to:
Resolved: No DLL File Generated with Built-In Sierra Chart Compiler
