Date/Time: Tue, 22 Apr 2025 10:35:33 +0000
Order Types on Trade Window
View Count: 506
[2023-03-09 15:02:31] |
User90125 - Posts: 715 |
I just looked at the Order Types for the Trade Window and couldn't find any info on the "Market Limit" order that shows at the bottom of the dropdown box on the Trade Window. TradeWindow-MarketLimit.png Could you look at this and advise what action would be taken when this order type is selected? And is this available for the Teton Order Routing service? Thanks. |
[2023-03-10 12:06:02] |
Sierra_Chart Engineering - Posts: 19305 |
This is a CME order type: https://www.cmegroup.com/education/courses/things-to-know-before-trading-cme-futures/futures-order-types.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-10 13:05:01] |
Thanks. For future reference, here's the specific link for Market-Limit orders at the CME Group website: https://www.cmegroup.com/confluence/display/EPICSANDBOX/Order+Types+for+Futures+and+Options#OrderTypesforFuturesandOptions-Market-LimitOrder Will the Order Types page be updated to include this order type? |
[2023-03-10 13:19:35] |
Documentation has been updated.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-10 13:19:40
[2023-03-10 14:41:19] |
Will users be able to specify this order type via ACSIL in a trading system study? Something like: NewOrder.OrderType = SCT_ORDERTYPE_MARKET_LIMIT
If not, could the ACSIL order type members be updated to add it? |
[2023-03-10 16:13:01] |
It is not supported and there are no plans to add this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-10 16:13:09
[2023-03-10 16:40:47] |
Wow, that's unfortunate since it's a supported order type with the CME and your flagship Teton Order Routing Service.
Date Time Of Last Edit: 2023-03-10 16:46:35
[2023-03-10 16:48:02] |
We would like to know if anyone is using it?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-10 16:48:14
