Date/Time: Tue, 22 Apr 2025 14:14:46 +0000
Zig Zag HH, HL, LL & HH Color Bar Based On Alert Condition
View Count: 736
[2023-03-09 03:30:59] |
User688525 - Posts: 284 |
Hello Sierra Support, I am using the Color Bar Based On Alert Condition study to highlight HH, HL, LL and HH generated by the Zig Zag study. This is working successfully, but only when the "Display HH, HL, LL, LH Labels" option is set to "Yes" within the Zig Zag study. The problem with enabling this option is that both the price and the label are displayed, when only the price is required. Is there a way to hide the labels without impacting the Color Bar Based On Alert Condition so that HH, HL, LL and HH bars are colored without displaying the HH, HL, LL and HH labels? Thank you |
[2023-03-09 15:48:50] |
We are not fully understanding the issue. There are separate inputs on the Zig Zag Study for Display HH, HL, LL, LH Labels and Display Reversal Price. If your Color Bar Based on Alert Condition is dependent on the HH, HL, LL, and LH labels, then they would need to be displayed. Another option would be to use the Spreadsheet Study and enable the Input on the Zig Zag study for Additional Output for Spreadsheets. You may be able to get what you need from the Spreadsheet study for the Color Bar Based on Alert Condition rather than directly from the Zig Zag study. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-10 01:18:55] |
Hi John, Where you have said "If your Color Bar Based on Alert Condition is dependent on the HH, HL, LL, and LH labels, then they would need to be displayed.", can the HH, HL, LL and LH labels be colored differently to the "Display Reversal Price", or are all labels confined to the same color? Thank you |
[2023-03-10 18:55:50] |
The only option for coloring the HH/HL/LL/LH labels is by the settings for the Subgraph, which allows for 2 colors. The coloring is based on whether it is a Low or High label. There is no other way to change the colors of these items.
[2023-03-11 09:18:46] |
Thank you for confirming.
