Date/Time: Tue, 22 Apr 2025 10:20:22 +0000
ASX data from CQG and CME data from Denali
View Count: 622
[2023-03-09 02:03:01] |
ammarbeyond - Posts: 2 |
Hello, I am using CQG / AMP as my broker and the ASX data works fine in Sierra but the CME data is not working. How do I use the Denali Exchange data with CQG while also keeping the ASX data. Thanks |
[2023-03-09 09:17:13] |
Sierra_Chart Engineering - Posts: 19305 |
You need to complete the CME exchange agreements here and activate the exchange: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliCME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-10 02:16:30] |
Thank you! Signed the forms and its working now
