Date/Time: Tue, 22 Apr 2025 10:23:19 +0000
Add Additional Symbols vs
View Count: 394
[2023-03-08 16:54:51]
User666529 - Posts: 4
how can I copy drawings from other charts to charts that I have added to my main charts by using the study "add additional symbol".
Copy Chart drawings from Charts in the Chart Settings doesn't work.
Thks
[2023-03-08 17:10:46]
John - SC Support - Posts: 39395
You can not use the study "Add Additional Symbol" to copy drawings. The only option for copying drawings between charts is outlined at the following link:
Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
When you say that this does not work, what exactly is not working for you?
[2023-03-08 17:59:02]
Basically I want 3 Charts exactly aligned below each other with same tieminterval (e.g. M5). Main Chart ES and YM + NQ below.
In the YM and NQ Charts I like to include my drawings which I have made in a different ChartBook on YM and NQ.
How can I do this most effinciently?
Normally I would use "Copy Chart drawings from Charts" in the Chart Settings. But this only works for the Main Chart (ES). How can I copy he drawings?
Private File
[2023-03-08 22:20:48]
Unfortunately, there is not a way to do exactly what you are wanting to do.
If you really want the drawings, then we recommend using 3 different charts and stacking them one above another (Tile Horizontally). You can then use Chart Linking and the Global Cursor to keep the charts in sync. Refer to the following:
Window, CB and CW Menus: Tile Horizontally (Window)
You may want to detach the charts and stack them outside of the main Sierra Chart window, in which case refer to the following:
Detaching and Attaching Chart Windows: Detaching a Chart
