Date/Time: Tue, 22 Apr 2025 10:32:32 +0000
Remote build error
View Count: 996
[2023-03-08 15:52:39]
dnrich - Posts: 18
I created an acsil study file that works well (test.cpp). Since today when I compile this file (Remote build) I have no error message, the DLL file is well created in the Data directory of sierrachart as usual. But this DLL file is not recognized by sierrachart as a valid file. Here are the messages resulting from the compilation.
HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (3) | Creating socket. Using TLS 1.2. | 2023-03-08 16:44:39.596
HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (3) | New receive buffer size: 32768 | 2023-03-08 16:44:39.597
HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (3) | Connecting to IP: 162.251.232.242. | 2023-03-08 16:44:39.597
Setting study DLL module function objects to indicate DLL is not loaded: C:\SierraChart\Data\test.dll | 2023-03-08 16:46:39.614
test_64.dll loading error. Windows error code 193: %1 n’est pas une application Win32 valide. | 2023-03-08 16:46:39.872
VersionNumber is 0 for test_64.dll | 2023-03-08 16:46:39.872
InternalVersionNumberToFileNameMap is empty for test | 2023-03-08 16:46:39.872 *
Error loading: C:\SierraChart\Data\test.dll. File not found or may be missing SCDLLName line. | 2023-03-08 16:46:39.872
Thank you for your help.
[2023-03-08 19:48:11]
ondafringe - Posts: 322
As a first step, did you check the top of your study to see if the SCDLLName is there and is syntactically correct, as this error suggests?
Date Time Of Last Edit: 2023-03-09 01:45:18
[2023-03-09 09:58:12]
Sierra_Chart Engineering - Posts: 19305
Provide us the source code you are building.
[2023-03-10 00:13:05]
SavantTrader - Posts: 110
Some of us are getting a remote build failure, with no error code or reason given. The source compiled fine just days ago.
-- Starting remote build of Custom Studies Source files: SavantTradingFlowStudies.cpp. 64-bit -- 19:08:11
Allow time for the server to compile the files and build the DLL.
The remote build did not succeed. Result:
No result text was given.
-- End of Build -- 19:08:12
[2023-03-10 00:24:26]
User275839 - Posts: 67
Same for me too. Build was working fine earlier today. Maybe the build machine is offline?
Message log sez:
HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Creating socket. Using TLS 1.2. | 2023-03-09 16:21:46.974
HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | New receive buffer size: 32768 | 2023-03-09 16:21:46.974
HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Connecting to IP: 162.251.232.242. | 2023-03-09 16:21:46.974
HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | CloseSocket call. | 2023-03-09 16:21:47.607
HTTPS connection ID:1 to build.sierrachart.com:443 for request ID:1 (2) | Shutdown started. Waiting for graceful close. | 2023-03-09 16:21:47.607
Build window sez:
-- Starting remote build of Custom Studies Source files: [REDACTED].cpp. 64-bit -- 16:21:46
-- End of Build -- 16:21:47
Date Time Of Last Edit: 2023-03-10 00:25:51
[2023-03-10 03:20:50]
jomo88 - Posts: 47
Same here. I have source files that built fine yesterday not working now.
-- End of Build -- 03:17:12
I tried doing a system restart etc no luck
[2023-03-10 03:28:16]
Tony - Posts: 565
I suggested that you guys build locally, which operating systems
are you guys using?
For Windows:
Download free "Visual Studio Community" and install, (select all C++ options in the installer window). In Sierra Chart, go to:
Analysis --> Build Custom Studies DLL and in the "Build Advanced Custom Studies" window: SC will automatically recognize "Visual C++ Path:"
and then go to: Build --> Release All DLLs and Deny Load
then go to: Build --> Build with C++ - Release
That's it, I never had to run Visual Studio once, I don't know how to use it anyway.
For Debian/Ubuntu Linux family:
Install G++-mingw-w64-x86-64 first
And then run a script something like this in a Old Post (#7):
cp ~/.wine/drive_c/SierraChart/ACS_Source/*.h .
x86_64-w64-mingw32-g++ -D _WIN64 -march=x86-64 -mtune=x86-64 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -std=gnu++11 MyCPPFile.cpp -o MyDLLFile.dll -Wno-deprecated &>Result.txt
cp MyDLLFile.dll ~/.wine/drive_c/SierraChart/Data/
rm MyDLLFile.dll
rm *.h
Any error messages can be found in file "Result.txt"
[2023-03-10 03:53:37]
jomo88 - Posts: 47
Thanks, building locally worked for me.
[2023-03-10 03:56:10]
Sierra Chart - Max - Posts: 5819
An update caused an issue with remote building. This has been resolved. Please try again.
Sierra Chart Support
