Date/Time: Thu, 28 Nov 2024 18:52:28 +0000
Study Summary does not sort correctly
View Count: 399
[2023-03-08 15:45:11] |
User365411 - Posts: 189 |
SC release 2484 Just discovered that adding any study to multiple charts to sort results in "Study Summary" window, does not work. It's like a textual sorting instead correct numerical sorting (img attached) Rolling back to december2022 2458 version it works as expected. Please advise TY Date Time Of Last Edit: 2023-03-08 15:46:48
Private File |
[2023-03-09 10:05:39] |
Sierra_Chart Engineering - Posts: 17206 |
We will look this over.
[2023-03-11 12:31:38] |
We will resolve this in the next release.
[2023-04-07 05:49:37] |
MarketWrench - Posts: 20 |
I'm not sure if I'am experiencing the same issue as the original poster, but, I also have noticed sorting is incorrect. The sort only seems to look at number in the greatest or first "place", for example 90 will rank higher than 1000 because 9 > 1. I find this to be the case when my study summary is sorted by the chart's spreadsheet formula study.
[2023-04-07 06:46:56] |
@ MarketWrench I'm on 2488 release and at the moment everything seems ok in the study summary window, not using spreadsheet. Date Time Of Last Edit: 2023-04-07 06:48:53
[2023-04-07 10:38:44] |
Update Sierra Chart to the latest release: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-04-07 10:38:49
