Date/Time: Tue, 22 Apr 2025 10:14:25 +0000
I do not receive Data Feed
View Count: 431
[2023-03-08 15:26:51] |
User214036 - Posts: 3 |
Hello Team, I need support with inputting symbols on my quote board. I input the symbol but when i click okay, it is not captured thus i don't receive data. Thank you |
Attachment Deleted. ![]() |
[2023-03-08 16:53:19] |
We can not reproduce this. When we enter a symbol and select OK, it inputs properly. Please try to load symbols using the Symbols button at the top, which will open a window where you can "Add" a symbol (select the Add button and then type in the name of the symbol). When you select the "Close" button on that window it should populate your Quote Board with the symbols you entered. Let us know if this works for you or not. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
