Date/Time: Tue, 22 Apr 2025 10:32:31 +0000
Question about Rithmic
View Count: 360
[2023-03-08 15:11:47] |
User925227 - Posts: 1 |
Hello, I wanted to know if I can use Rithmic in my current account? IF not, what would I have to do? Thanks |
[2023-03-08 16:25:36] |
Yes - you can use Rithmic with your current account. Refer to the instructions at the following link to connect your Sierra Chart to Rithmic: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
