Date/Time: Tue, 22 Apr 2025 14:00:07 +0000
Create a Chartbook to only show indicators
View Count: 486
[2023-03-08 14:26:22] |
moveupwithmike - Posts: 25 |
What's the best way to create an intraday chart but only show the indicators with no price graph
[2023-03-08 15:52:14] |
Tony - Posts: 565 |
This will hide main graphs: Chart --> Graph Draw Types --> Blank For subgraphs, you will have to go to study settings and Subgraphs tab, select the subgraph you want to hide select 'Hidden' for Draw Style |
[2023-03-13 07:22:56] |
That's how you remove the candles, lines, bars whatever you use to chart the price; however, I am asking how to make a chart that onlys the indicator. With change the graph draw type the x-y axis of the main graph still shows. I only want to see the indicator.
[2023-03-13 11:38:34] |
Sierra_Chart Engineering - Posts: 19305 |
Refer to this setting: Chart Studies: Settings and Inputs Tab >> Display As Main Price Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
