Date/Time: Mon, 15 Dec 2025 09:09:44 +0000
Tab bottom color display
View Count: 802
| [2023-03-08 12:28:38] |
| Misanirina - Posts: 47 |
Hi, I'm looking for how add or change color for each tabs at bottom display. its possible ? Thanks |
| [2023-03-08 15:50:53] |
| John - SC Support - Posts: 43443 |
You can color the Active tab and Inactive tabs (i.e. only those 2 color options). Refer to the 5 settings starting at the following: Graphics Settings: Chart Selected Tab Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2023-03-08 16:51:35] |
| Sierra_Chart Engineering - Posts: 21843 |
There is also this setting: General Settings Window: Color Chart Tabs with Chart Link Number Color (Global Settings >> General Settings >> Charts >> Charts) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-08 16:51:50
| [2023-03-08 17:03:29] |
thanks a lot
