Date/Time: Thu, 19 Sep 2024 01:03:58 +0000
Silver spot rate 10 years Daily data
View Count: 1029
[2014-06-16 03:51:13] |
plaforte - Posts: 13 |
Hello, I cannot figure out which SC data package I should subscribe to get 10 years of Daily data for silver spot rate ? Thank you
[2014-06-16 18:41:53] |
You will need Sierra Chart package 1. To get this data use the Sierra Chart Real-time and Historical Forex/CFD Data Service: https://www.sierrachart.com/index.php?l=doc/SCRealTimeFOREX.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
