Date/Time: Tue, 22 Apr 2025 10:26:17 +0000
Trouble connecting to data feed
View Count: 440
[2023-03-07 20:28:48]
User434438 - Posts: 2
I'm trying to connect to the delayed data feed: I went to Global Settings Data Trade Service Settings and set Trading Evaluator-Delayed, but when I go to file connect to data feed it's grayed out.
I would also like to know how to convert my trial {it's not expired yet} to a regular monthly subscription.
Thank you.
[2023-03-07 23:11:55]
John - SC Support - Posts: 39395
You can not select "Connect to Data Feed" because you are already connected.
You do not need to do anything special to get the delayed streaming data for the CME Group, CFE, EUREX, and NASDAQ TotalView exchanges. Just use the Find Symbol window to find the symbol you want, and since you are not setup to get the real-time data, you will automatically get the delayed streaming data.
If you are still having an issue with data, then we would need to see your Message Log by following these instructions:
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart. Tell us about *one* symbol only.
