Date/Time: Tue, 22 Apr 2025 18:33:49 +0000
NQTV Stock Intraday data
View Count: 471
[2023-03-07 18:30:27] |
Dan the Man - Posts: 92 |
Hi John, I set my intraday data using the Data Limiting in the Chart Setting. I doesn't seem to matter what I do, there is only about 20 days loaded. I attached an image showing this on a 45 minute chart with the chart setting and Symbol setting. Kind Regards, |
[2023-03-07 19:13:58] |
Sierra_Chart Engineering - Posts: 19305 |
There is only 12 days of historical data available for the symbol. That is all that is available. Must be a new symbol.
[2023-03-16 19:18:10] |
Hi John, I'm back with the same issue and I'm using the symbol OXY-NQTV. This company has been around forever. I am see this on most of the stocks I'm looking at. I set my intraday data using the Data Limiting in the Chart Setting. I doesn't seem to matter what I do, there is only about 60 days of data that will load. I attached an image showing this on a 45 minute chart with the chart setting and Symbol setting. Kind Regards, |
[2023-03-16 22:28:22] |
John - SC Support - Posts: 39418 |
The data is definitely there for OXY-NQTV. We have gone back to August 29, 2022 at least. Follow the instructions at the following link to get more Intraday data: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-17 17:53:37] |
Hi John I followed the above and was able to chart more data. But, on this stock BTE, There is data missing as per the attached image. I used the Intraday Data Editor (image attached) but still have the gap. Regards, |
[2023-03-17 18:01:06] |
Usually this will mean that this is a new symbol and years earlier the symbol must have been used by a different company. So there really is no missing data. It is correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-17 18:04:00
