Date/Time: Tue, 22 Apr 2025 14:26:36 +0000
[Programming Help] - %d, %s; %f ?
View Count: 733
[2023-03-07 11:40:06] |
BenjFlame - Posts: 337 |
Hi, When logging with Format() I was thinking that those were just place holders, but it seems it's not that simple since sometimes passing a value with the wrong % won't work. What are all the %xx there is? Where to learn about it? |
[2023-03-07 12:19:30] |
User431178 - Posts: 654 |
ACSIL Programming Concepts: SCString Methods Search printf using your preferred search engine or look here https://cplusplus.com/reference/cstdio/printf/ |
[2023-03-07 13:53:34] |
ok thanks. Here is the code I'm using: if (sc.MenuEventID == 6) { s_SCNewOrder NewOrder; NewOrder.OrderQuantity = 1; NewOrder.OrderType = SCT_ORDERTYPE_MARKET; NewOrder.TimeInForce = SCT_TIF_GOOD_TILL_CANCELED; int Result = sc.BuyEntry(NewOrder); // Order data s_SCOrderFillData OrderFillData; sc.GetOrderFillEntry(sc.GetOrderFillArraySize() - 1, OrderFillData); // Log SCString DebugMessage; SCString symbol = OrderFillData.Symbol; uint32_t OrderQuantity = OrderFillData.Quantity; DebugMessage.Format( "OrderID: %u, Symbol: %s, FillTime: %s, Type: %u, Quantity: %u, FillPrice: %f, PositionQuantity: %u; IsSimulated: %u", OrderFillData.InternalOrderID, symbol, OrderFillData.FillDateTime, OrderFillData.BuySell, OrderQuantity, OrderFillData.FillPrice, OrderFillData.TradePositionQuantity, OrderFillData.IsSimulated ); sc.AddMessageToLog(DebugMessage, 1); } Several problems: - Symbol doesn't seem to display a string... it displays a binary character. Data is supposed to be a string, so I don't know why. - Same problem for Fill time: how to display that one ? Last: Position quantity is always 0. Even if I stack orders (I'm in simulated environment). If you have clues on how to solve theses... thank you |
[2023-03-07 14:47:25] |
Here is some more complete information, maybe it is helpful - https://en.cppreference.com/w/cpp/io/c/fprintf Symbol doesn't seem to display a string... it displays a binary character. Data is supposed to be a string, so I don't know why.
You would need to use symbol.GetChars() as functions expects char* not SCStringSame problem for Fill time: how to display that one
For converting SCDateTime to string, take a look at sc.DateTimeToStringACSIL Interface Members - Functions: sc.DateTimeToString() Last: Position quantity is always 0. Even if I stack orders (I'm in simulated environment).
TradePositionQuantity is double not unsigned int, i.e. f not u
Date Time Of Last Edit: 2023-03-07 14:48:12
[2023-03-15 12:04:24] |
Note for self, print: typeid(a).name(), where a is a variable name.
to know the actual type. Date Time Of Last Edit: 2023-03-15 12:04:40
