Date/Time: Tue, 22 Apr 2025 10:35:36 +0000
Problem
View Count: 281
[2023-03-07 11:23:16] |
bullhaktrades27 - Posts: 4 |
I am back for more with SC, trying to not give up on myself, understanding it one day. I seem to have connected all my data but I can not figure out how to get any of my instances to give accurate visuals. I have played around: going into Chart and then into Perform Futures Rollover but that didn't seem to pop up the stuff I want to see. I have my DOM open, and my footprint but the Footprint is stuck at 4250. I tried doing a rollover but that doesn't seem to change anything. Nevermind actually it went through just now, but it cleared the whole page, the instance is still open but completely grey, and I can't see my Footprint now. I have been trying to noodle around with setting everything back up, and I can't seem to crack it, would appreciate any help. Thanks! |
[2023-03-07 11:23:52] |
Sierra_Chart Engineering - Posts: 19305 |
You need to activate the exchanges that you need here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed After that: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-07 14:47:12] |
Ok, going to give this a try, thank you very much
