Date/Time: Tue, 22 Apr 2025 10:32:33 +0000
How do I place an attached OCO limit order by direction clicking on the chart?
View Count: 350
[2023-03-07 04:43:30] |
User280673 - Posts: 27 |
I want to be able to execute a trade directly on my chart. I know you can left-click and use the drop-down menu. However, I want to be able to click similarly to on the DOM via command. I am struggling to find it online and I am pretty sure I had this feature on my setup but lost it due to adjusting my workstation. |
[2023-03-07 09:19:44] |
Sierra_Chart Engineering - Posts: 19305 |
Maybe you are referring to this setting: Chart Settings: Extend Chart DOM Across Entire Chart When Using Ctrl(Buy) / Shift(Sell) (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
