Date/Time: Tue, 22 Apr 2025 10:26:22 +0000
Custom Combined Futures Symbol
View Count: 400
[2023-03-07 03:00:00] |
User610087 - Posts: 2 |
Hello, Is it possible to combine 2 symbols into a single futures intraday chart.. For example (F.US.EPH23 + F.US.ENQH23) Thank you |
[2023-03-07 17:16:11] |
First, take a look at the Continuous Futures Contract option. If you are wanting contiguous contracts, then this is the best way to do it. Refer to the following: Continuous Futures Contract Charts Otherwise, if you want to put together two non-contiguous contracts, then you could use the Custom Calculated Symbol to do this. Refer to the following: Custom Calculated Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-07 18:42:44] |
Thank you, Working on the 2nd option "Custom Calculated Symbol" with the following: 1*{F.US.ENQH23}+1*{F.US.EPH23} appreciate any further feedback, but will dive into the thread sent further. |
