Date/Time: Tue, 11 Mar 2025 05:11:04 +0000
decimal problem yen Sierra data and CQG
View Count: 1125
[2014-06-15 22:13:44] |
N!co - Posts: 140 |
Hi, How do i fix this decimal problem between Sierra data and CQG thank you |
[2014-06-17 09:52:54] |
This has been resolved. Restart Sierra Chart and then reopen that chart.
[2014-06-17 12:01:51] |
N!co - Posts: 140 |
HI, Downloaded the new version closed Sierrachart and reopend closed chart and reopened deleted all data and downloaded again but the probems is still there Date Time Of Last Edit: 2014-06-17 12:02:17
[2014-06-17 16:32:27] |
Update the Symbol Settings as explained here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettings After this, apply them to the chart by following these instructions: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateChartSettingsSteps When we said reopen the chart, we meant to actually open a new one through File >> Find Symbol. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-06-17 16:33:10
