Date/Time: Tue, 22 Apr 2025 10:23:19 +0000
[User Discussion] - Volume Profile (peaks/valleys) do not reconcile between Sierra and IRT
View Count: 434
[2023-03-06 19:34:38] |
MightyMommy - Posts: 6 |
Hello this is my first time posting for help. I'm trying to convert my IRT VP chart into Sierra and I am unable to reconcile the peaks and valleys (aka as CLVN/CHVN) between IRT and Sierra. Can you recommend a setting that I may need to update? I attached a file with screen shots and settings from both systems. Thank you so much in advance.
[2023-03-06 21:54:26] |
We can not help with comparisons to other systems. The only thing we can do is to point you to our documentation for how our system works. In this case, refer to the Inputs starting at the following link (and the 2 Inputs after it): Volume By Price Study: Draw Peaks and Valleys For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-07 20:12:57] |
Ok I understand thank you. I will try to reconcile it on my side but can you point to how to figure out what is considered a "day"? I think I will have to start by figuring out if it includes the evening session or just RTHs. Thanks so much for your help.
[2023-03-07 23:06:41] |
That depends on how you have setup your Session Times and how you have set the Inputs for the Volume by Price Study. Refer to the following for Session Times: Chart Session Times And refer to the following Input for the Volume by Price study: Volume By Price Study: Use Separate Profile for Evening Session For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
